Help on an Exhaust
Doesn't link buddy! Have you tried to find the part number for the original and has yours been changed since factory?
Thanks, not sure why... this is the part number on the site 704740751 and 705740891
It is all standard but has been changed, I suppose it is one of those things I will have to take it into a mechanic to actually look at.
After a little help on my exhaust, I am buying a standard one as mine is blowing and need a quick fix.
I got one from Euro Car Parts, found it through a reg search, bought it and the mechanic says it is the wrong one.
I have a 2002 Phase 2 172
http://www.eurocarparts.com/exhaust-parts
Any pointers?
Thanks in advance
Dan
I bought handbrake cables for same model car as yours from there and they didn't fit either.
If possible give them the OE part numbers to cross ref the exhaust and try looking at it before you buy it.
Euro are really bag with wrong parts and a mix mash of things. Like above with certain parts (Hand brake Cables) you need to go OE but I'm sure the exhaust should be straight forward.
Look like special order jobs to me, obviously can't be 100% as I don't work there anymore and can't check. Those Klarius numbers should help you, though.
Careful with online part finders.
I always used to end up with Megane parts for my '53 plate 172. As did garages.
mental
