Help on coilovers (ohh no not again)
  Clio 1.2 16v mk2 ph2
sorry to re-post on a very common topic but its messing with my head :/
as i have a 1.2 16v i think that strut bolt spacing is 58mm. correct? also the ones that state they have 58mm spacing say they are not for the 1.2/ 2.0 16v. any advise??
Measure it. Take the front wheel off, where the strut bolts to the hub, measure the distance between the two bolts from top of one to top of the other. Done.
The top mounts are all the same from 1.2 right up to 2.0. You don't need to worry about the width on the hub unless you have a Campus.
  MK2 PH2 1.2 16V
If you've got a 1.2 16v its more than likely to be 58mm, if you are unsure just measure it like JCC said but yes everything else will be the same.
