HELP on fitting samco hoses
bought the main water hoses 2day,came to fit the main 1 you can see which goes from your(below the bleed screw) rad to the aux water pump then into your engine,but the next 1 what a pain had to remove the rad and a load more stuff eg bumper,so i have a pipe goin from the water pump,rad,then a split were it goes to the aux water pump then another split and this pipe goes no were then at the end of the main pipe it goes onto a metal rail!!!! were does this split of a pipe go? ere is a link to the pipe its the 1 with a long bit comin out of it http://forum.cliosport.net/display_topic_threads.asp?ForumID=3&TopicID=102337&PagePosition=2http://forum.cliosport.net/display_topic_threads.asp?ForumID=3&TopicID=102337&PagePosition=2
