help on my rough idle !!
Car  Clio Sport 172
Hi all !! I know its another post about rough idle but i didnt found an answer to my rough idle yet..
Sometimes it idles at 1250 (never less) but other times it idles at 1500, 2000 or in values between. I ve checked all the intake for any vacuum leak and everything is fine. At the moment im using an inovate lc2 wideband with the narrowband simulated signal in my oem ecu. Can this be the cause to the problem?? The afr in the idle its always 14.2 , 14.3 doesnt matter the rev.. thanks in advance mates..
