Ok I have purchased a Janspeed decat form my mk2 172 which has two lambda sensors, 1 before the cat and 1 after.
When thinking about this the two sensors are obviously giving the ecu different readings with the cat on but with the decat fitted the two readings should then be the same .
So what I want to know is will this affect the ecu ie giving it b****cks info from the second sensor and not running as well??
The cat is there to bring down emissions right?? so if the second sensor is getting the same reading as the first would before the cat will it not then think there is too much fuel going through and in turn reduce that??
Im lost!!
Do I have to get a chip or ecu at the same time as a decat??
