HELP ph1 172 will not start
gudger12345
Car  Ph1 172
I will have to admit that i washed the engine and may have got it a little wet a couple of weeks ago :dapprove:
I have since fitted an aftermarket steering wheel and replaced the standard seats with reclining mono bucket's and harness
The car will lock and unlock with all the interior electrics working correctly and indicators flashing etr, however there is a red LED near the gear stick which did flash however doesnt seem to work now
I have removed the inlet manifold to check that there is a spark at the plugs and there unfortunatly is not
I have also checked the fuel pump which has no power, but if you supply power to it, it will pump
I believe it could be related to the factory Cobra alarm system
Please could anyone shed some light on the situation it would be much appreciated
