Help please knocking noise.
Car  182
Hi guys looking for some advice, I get a loud knocking noise coming from the front left of the car when under hard acceleration. car is a 53 plate 172 cup.
Good chance it could be the engine mounts, possibly steering rack related?
Maybe check the suspension/top mounts
.. i have changed the mounts all round and it still knocks under hard acceleration; common fault that you have to get used to :(
A thing that seems to cure it is to loosen up the two top enginemounts and pull the engine forward and retighten. this will get rid of the engine hitting the subframe..temorarily
people should tail it a bit on testdrive when buying it because they all have it... wo'nt be as much of a surprise then
had the same problem a month ago. knocking under hard acceleration in 1st &2nd. replaced the engine mount under the battery holder and it's gone. Hope this helps.
Have you had a wet wheelspin yet since the change ?
Bet you it WILL knock.. need a wheelspin to find out
They will knock when in the rain wheel spinning
I have fiited two mounts to a car today and the noise is gone.
had my mate check it and reckons it is the lower mount. any ideas on a price for this? should i get another standard mount or up rate it?
