help rear discs
hi every1, im sure its a much talked about topic, but am unable to find any threads on it. does anybody now the procedure for fitting after market rear discs please, ie can o.e bearings be pressed out of old and into new ? and abs ring ???? help been told it will pull of with pullers and press on new disc ? is this info right. :)
[Edited by VA52OGF on 07 January 2005 at 12:06am]
get newbearings, they are cheap and its not worth the hassle pulling out the old ones.
The discs will have the ABS ring on it already.
Apart from that, its just remove caliper, undo stub axle bolt, swap disc, put caliper back on.
not that easy mate, take it back
pop down to renault, they supply the abs disks with bearings in them as std and you just pop them on.
oddly enough they are well priced from there as well
Andy
GDI
