HELP: Removed my 182 Gearbox, more than Thrust Bearing Broken
  Titanium Clio 182FF
Hi, I recently purchased a 182 with my dad that had an issue (which we were aware of before buying). The clutch fork wobbled around when the car was just idling, with so much movement that it was hitting some pipes. When releasing the clutch when pulling off the car would judder violently and when trying to go into reverse it would grate and we'd have to switch the car off first. When the car was up to speed though, it changed between 2nd and 3rd, 3rd to 4th etc. fine enough, though the clutch bit really really early, like a finger's distance from the floor, so I assume the ratchet adjuster or cable may be at fault (the cable is a cheap plastic thing that I will replace). Other than those issues, the engine, suspension, bodywork, etc. was in good nick, and the price was reasonable, so we took it, hoping to fix it up ourselves on our driveway.
Now, the previous owner apparently had the syncros and clutch done only 5000km ago, and they said they didn't have the flywheel skimmed. However, I'm not sure I trust the quality of the work done by whoever they took it to, and we planned while the gearbox is off to inspect the clutch disc and flywheel myself, and I think I'm going to have the box inspected and potentially refurbished professionally.
We managed after a lot of trouble to remove the gearbox, and as we suspected, the thrust bearing was ruined. However, this other thing the thrust bearing rides on which I'm not entirely sure of its name is also broken.
Some pictures:
NorthloopCup
That’s the 3rd guid tube in almost as many weeks that’s fucked like that.
Best advise is don’t skim the flywheel either. They don’t respond well to that and it makes them a potential point of failure - especially if they take too much meat off.
  Titanium Clio 182FF
Thanks for responding so soon😂 At least I'm not alone, why do you think the guide tube got so fucked as you put it? The tube was even flared at the end where it meets the pressure plate, like a rolled lip, so much so that the thrust bearing won't even come off. Only thing I can say is that the state of the rest of car shows that whoever worked on it cut corners (the front struts had no rubber seats below the springs for example), and may have taken the previous owner for a ride.
BTW, I haven't yet removed the clutch and pressure plate as it was getting dark, but I noticed once the box was off that the flywheel seemed like it has two separate sets of teeth, the height of the inner ring was shorter, so it may be a dual mass flywheel.
Perhaps if it is a dual-mass, the clutch and pressure plates aren't the same between dual mass and non-dual mass flywheels, and the person who installed the new clutch didn't install the correct one? And as for skimming the flywheel, does that mean when changing the clutch and pressure plate, as long as there's still meat on it, and it isn't otherwise ruined, that it can just be reused as is and won't have any issues interfacing with the new clutch disc?
Also, I'm wondering whether it will also be advisable or necessary to change the clutch fork, it shows shiny metal where it's supposed to contact the thrust bearing and may be unevenly worn, although I didn't check it thoroughly yet.
NorthloopCup
Thanks for responding so soon😂 At least I'm not alone, why do you think the guide tube got so fucked as you put it? The tube was even flared at the end where it meets the pressure plate, like a rolled lip, so much so that the thrust bearing won't even come off. Only thing I can say is that the state of the rest of car shows that the previous owner/owners cut corners and penny pinched (the front struts had no rubber seats below the springs for example), so I wouldn't be surprised if they took it to some second rate mechanic who had never touched an RS in their lives.
I think the reason they’re failing is due to age mate tbh. Many heat cycles have gone through those clutch guide tubes now.
As above, single mass flywheel not dual.
Regards the flywheel, if there’s no significant grooves in it, or cracks that you can fit your finger nail in, just clean it up with emery paper on the surface and refit/replace the clutch.
  Titanium Clio 182FF
Not a dual mass on them.
Two sets of teeth is right, the ones at the back are for the starter and the front set is for the trigger pattern on the crankshaft sensor.
Well, that's a relief😅
Makes sense, I hope I can find a guide tube in South Africa🤞🏻 As for the flywheel, I'll definitely give it the once over in the manner you stated. Thanks again.
  Titanium Clio 182FF
@NorthloopCup Hi again, does the flywheel have a pilot bearing? I don't seem to see it. Also, don't worry about the oil leak, I'm changing the oil seal too!
  Titanium Clio 182FF
That's the bracket that sits on the outside of the gearbox at the bottom, to hold the rod attached to shifter linkage in place. I might have a picture of one somewhere.
Edit: Terrible picture but it sits down here:
Thanks! I'm wondering if that isn't for the dogbone, because I looked the shifter linkage is much further to the left?
  Titanium Clio 182FF
That looks correct. When it's tightened up, the lower hook of the bar goes tight to the bottom of the mount. Not sure what the other hooked bit on the mount is for. Of course I could be majorly wrong but that looks fine to me.
Perfect, thanks again!
As above, looks spot on. Nice and clean under there 👌
Great, thanks😂 It wasn't like that a couple of weeks ago when we bought it! Years of caked on oil and grime from a leaky rear main seal and sump gasket, both of which we fixed when we had the box out! The gearbox, sump and entire subframe were dark brown and greasy, now you could eat your supper off of it!
  Titanium Clio 182FF
Welp, should've listened to your advice better... I have an issue, and at the end, I have my plan for a potential solution, and I'd appreciate it if you could let me know how feasible it is.
The Problem
I'm currently experiencing an awful clutch with juddering when pulling off, not as violent as when I first got the car, but enough to mess up the dogbone which I had to replace, and it the replacement even looks like it needs replacing soon. Here's what happened:
  • When we took the gearbox out, my flywheel didn't look great as it had plenty of grooves in it and seems a lot of material got eaten away (not by skimming). It still had a raised surface where the clutch disc contacts it but as I said before, the material inside that area was worn down what felt like quite significantly and had plenty of grooves. Here's a picture:
  • The clutch disc only had friction material on some of it, the rest must have broken off:
  • I saw an ad on the Renault RS Club of South Africa Facebook page about a guy that reconditions RS clutch kits, and after contacting the guy he quoted me less than half the price of a new clutch kit for a reconditioned kit and flywheel skim.
  • I asked him whether he could do it without skimming the flywheel, but he refused, claiming and I quote: 'The Flywheel must be skimmed 32 Years Experience..really are welcom to view our work on facebook page, and see for yourself how many Renault clutches we did..the skimm is necessary, and you dont have to worry we are not taking of milimeters its still going to be standard,is to check all the heights because linings thickness differ..'
Anyway, I decided to throw caution to the wind and go ahead with the reconditioning, as the surface of the flywheel as it stood didn't look like it would work nicely with a new clutch kit alone, even if I roughed it up with some emery cloth. Here's a before (left) and after (right) of my clutch kit and flywheel:
When I got it back, he had machined the flywheel surface down to where there's no raised portion at all, the entire flywheel was flat. However, the clutch disc material was apparently made thicker to compensate. In his words: 'we use very strong linings got copper in,use it also on trucks..', ' its very thick linings that we use'. When I showed the picture to someone else, they commented that due to the high copper content it looks almost like a button racing clutch instead of a street clutch. This is a daily driver street car, so that's not desirable. The surface of both the flywheel and pressure plate both had visible machining marks that could also be felt.
Either way, we put the flywheel and clutch kit back on the car, but in following the Renault guide, we didn't grease the spigot shaft AT ALL, not even a thin film of it:
Right now the clutch pedal creaks and doesn't press in smoothly if you press it slowly and has tiny but noticable jumps in its travel (maybe the clutch disc is binding on the splines of the spigot shaft?). We did however, use molybdenum grease on the new guide tube and thrust bearing. BTW, the new guide tube had a somewhat rough, cast surface, is that alright?
At first, the clutch felt fine enough, but it's been about 600 miles and the juddering when pulling off just got progressively worse and worse, now requiring you to accelerate hard and intentionally ride the clutch and burn it in order for it not to judder your face off.
Idea for a Solution
Since finding a replacement flywheel is nearly impossible, my father had another plan:
Have an engineer machine the flywheel so that area surrounding the mating surface of the flywheel is raised in order to restore the deck height. Since the bolt holes for the pressure plate are countersunk, redo the countersinking so the pressureplate sits how it used to. Have them skim the surface slightly before doing that to make sure its straight and true, and once everything is done, ensure the surface isn't too rough.
I'm curious to know what you think of that idea, I'd just need the height difference between the deck and the rest of the flywheel to do it, would you happen to know what that is on a brand new flywheel? I don't have many alternatives in South Africa unfortunately, apart from a used flywheel that's several hundred miles away and needs to be paid for in advance, here's a picture of that flywheel, it looks like the right one to me but I'll leave that for you to judge:
  Titanium Clio 182FF
Correction: so that the area surrounding the mating surface is LOWERED, thereby making the mating surface a raised area again.
Also forgot to mention I'm going to get a standard clutch kit once I have a decent flywheel again, either a Valeo, Sachs, LUK or a Blueprint kit.
NorthloopCup
So in theory, the idea sounds simple and like it’ll work. But the issue comes with removing material from the standard flywheel isn’t really ideal as it can weaken them as they’re only cast.
I can’t give you any measurements either I’m afraid as I don’t have a flywheel that I could measure. I imagine someone on here would be able to measure one for you though.
The better solution would be to replace the flywheel with a lightweight item - I’m pretty sure pure motorsport or ktec would ship to SA?
The clutch guide tube should also be smooth.
Brigsy
  T.Turbo
Last time i had clutch judder on a car shortly after replacing it was faulty clutch. Also guide tube issues caused similar on another.
I dont think flywheel will be causing the issue as ive had one skimmed the same way without issues on my renault extra. I also had no choice as issues with grooved face.
  Titanium Clio 182FF
Thanks for the replies, I considered a lightened flywheel but I've already spent plenty on the car in the last 2 months, so a brand new one is out of the question unfortunately.
As for the state of the current flywheel, if the completely flat face is fine, perhaps it doesn't need replacing at all. However my concern is that since there's now a larger gap between the pressure plate and flywheel, the clamping force will be lower now if I put a standard clutch kit on, is that likely to be the case and cause a problem?
Also, regarding the small things, should I add any amount of grease or lubricant to the spigot shaft? Has anyone used a Blueprint clutch kit before, they're a part of the Bilstein group and they have a clutch kit for my 182 readily-available for a decent price. A Valeo one will be difficult to source.
NorthloopCup
Let me see if I’ve got an old flywheel up in the garage loft. If I have, you can have it for whatever the postage costs are.
