I'm trying to install a hardware firewall on a network but I've got stuck and can't get it to work.
Setup:
Cable modem (ip: 192.168.100.1) plugs into Server WAN NIC which has two ip addresses on the card 192.168.100.2 and 77.77.77.77 (companys static ip - this is just sample) and a gateway address 77.77.77.76
Now when I plug the modem into the WAN port on the firewall I tried to give the WAN port the static IP of the company's static IP address of 77.77.77.77 and gateway of 77.77.77.76 and changed the WAN NIC on the server to a private IP and used NAT. BUT I can't get internet access or anyrthing.
Maybe I need to put the ip of 192.168.100.2 on the WAN port but then where the hell do I put the static IP address of the company? I can't assign two ips on the WAN port unlike windows routing and remote access.
Thoughts?
Setup:
Thoughts?
