help starter motor help
Car  ph - Quick Silver!
basicaly the red wire with the spade connecter on the end that connects to the starter has been siting on my manifold an burnt away:mad: what type of wire should i use to replace this and were can i get it from help
Anything the same thickness. just snip it off just before the f**ked bit and solder the new wire to it and then shrink wrap it after, job done.
Or..
Replace the whole wire (i wouldnt bother)
Edit: and when i say same thickness wire, i mean the inside of the cable (the wire it self) not just the outside.
do u know where i can get some wire from? (halfords) can i use amp power wire? and where do i get shrink wrap from sorry if i sound dumb
