Help temperature problem??
OJD
  clio 172 ph1
Hi all l have a clio 172 ph1 has had a water pump, dephaser pulley, timing belt kit and aux belt kit all genuine items trouble is the temperature gauge on the dash is sitting at a quarter instead of half way could it be because I have fitted a non genuine thermostat and coolant temperature sensor oh and also there is a just a mixture of coolants in the system again not genuine type d coolant all help would be appreciated thanks Owen
OJD
  clio 172 ph1
Bump anyone?? Took the car for an hour long drive tonight then last 5 mins gave it a bit of stick wouldn't rev over 6.5k instead of 7.2k anyone ideas???
OJD
  clio 172 ph1
Yeah tried 2 thermostats and 2 coolant temp sensor sensors non genuine to no joy looks like a should of just bought genuine can be the only things that won't allow it too heat up surely?
OJD
  clio 172 ph1
Yeah had the blead screw out when filling up with coolant them when it had a constant flow coming out put the screw back in so ave had to order a genuine thermostat and coolant temp sensor so hopefully this cures it if not don't really know what to do from here?
OJD
  clio 172 ph1
Well replaced the thermostat and coolant temp sensor flushed the entire system and filled with genuine type d coolant cars running great lot to be said for using genuine parts won't be making that mistake again!!
