Help with Headunit wiring....
I have had a headunit and an adapter so that I can use the volume stick near my steering wheel put into my car a couple of weeks ago. It was working fine until I put my sub and amp into my car, since then everytime I go over a bump or hit the side of the foot well it makes the headunit beep like theres a lose wire or something. Does anyone kno if it could be the adapter that is conflicting or does it sound more like a loose wire? If it is a loose wire what colour should I be looking for to see if it has come out?
Thanks again, Ads
hmmm ok thnx. The only thing is im not to familiar with all the wiring in the car so where would be the best place to take it to get some1 to look at it?
Ads
Ads
Unplug the sub and ap see if that fixes the problem work backwards until the problem goes away and you'll have a better idea who to fix it.
Depends where you are what auto electrical you want but you could be paying a fortune for them to fix something you could sort yourself.
