help
Car  you may know it, clio?
ok connecting my sub...
i've ran the wires under the carpet, into the head unit
but how do i connect the sub battery?
New cable from battery through the bulkhead to the amp under the carpet.
If you look up in the passenger footwell you can use the bonnet release cable grommet to feed the wire through without drilling a new hole if you wish.
Its the thing on the left with the cable going through it, your ok up to 4awg cable.
ok cheers mate
this does help alot
i thought about it but seemed a bit tight.x
or if you want, put it down the Wing and through were the Door hing is, and under the seal into the fot well up into the dash :)
imo the release grommet is the best way barring getting the drill out, through the door seal is a bit pikey.
