Everything about mine is pants until it gets warm.
Unresponsive
Exhaust a bit tinny
Uncomfortable gear changes
Suspension squeaks
Cold internal plastics seem to rattle more
And im usually frezzing my tats off !!
Once its warmed up, all this goes away and is a smooth rocket lol
Mine too. Completely standard, just had a service, and still doin it! 5 mins gentle drivin in the mornin and its fine tho.. Just somthin you have to live with..
Cold start sensor fitted in the thermostat housing
When the car is cold in the morning it detects the water temp so therefore increases the amount of fuel / air going to the engine. If the sensor is faulty it can be like trying to start a car with a manually operated choke without pulling the choke out but not as severe - the car will sometimes stall and misfire / pop until warm. The cold start sensor detects water temperature this increasing fuel / air mix when cold and then decreasing when the engine has warmed up. I would personally change the TDC sensor as well as these are always going wrong.
There is another problem with the F4R engine which does involve re-programming the ECU. If you contact your local Renault workshop and ask them to have a look at the car under a tech note 3585A. This can only be done on the clip or Optima 5800 and takes 0.3 hrs to do.
