Hexlogic pads which ones ?
Yeah theyre good. Tend to break up on the edges when using with a rotary I found, DA they are fine.
Green hex pad with Power finish 203s is a good one hit solution for my car if thats of any use.
Shame 3M dont make a waffle pad inbetween the yellow and Green one as those are my favorite to use.
Cheers mate I'm trying to buy a few different combo,s of pads as I'm buying a da on it's own with no pads polishes just wanted to no what was worth using
Are you new to this silly game?
I strongly suggest you buy this kit, as im sure others will too. Great machine and good pad/polish combo too. Especially for clios. When you move onto harder paints, like BMW, then look into Megs 105 and other heavy cutting compounds.
203s/Power Finish is a mix between good defect removal and a decent finish. Like I said, great one step product.
http://www.cleanyourcar.co.uk/polis...as-6-pro-sonus-and-menzerna-kit/prod_677.html
I would agree. Pearce; by buying separately you will do yourself out of a few quid. The Sonus pads are very good for new users to machines. They are hard wearing and have a good range of cuts, from harsh to finishing.
The Menz polishes are, again, what I would advice (;)) for a new starter and a veteran alike. Superb range of cut and the polishes finish down very well on all finishes.
The only addition to the above, re pads, would be a spot pad and backing plate.
Cheers lads I was gunn a buy the one off here in the for sale section the meg one but I'll leave it now and buy this instead
