Hi advice on a v6
I think you should join Cliov6.net-
Also Ali has a good owners thread on here-
However how bigs your wallet- firstly whatever one you buy I would have a GOOD £500 spare for emergencies as part cost an arm & a leg-
- FSH is essential as is low owners-
- Cambelt & water pump should have been changed- ideally by main dealer or qualified specialist ( make sure you have an invoice)
-look for the usual accident damage- check HPI
- steering wheel perishes-
- check the air con- dont take its out of gas as a cheap regas- the pipes to the pump are under the car & often get hit- looking around £200 there at least-
- check under the bonnet & under the tray - for damage- make sure all the bolts are there as they are £30 a bolt-
- tyres... you dont want budgets on the rear--
- alloys- the finish from the factory is poor- will have needed refurb-
- check for both arch lines- as these are a good sign of damage if they are missing-
- If you join Cliov6.net- you can check the plaque number
- Dont buy from ron hodgson ( mega overpriced) or West sussex car specialists- as they lied about an accident hit vee-
- Clutch falls to bits- look for one thats been replaced when the owner did the belts otherwise its another 1k at least down the swannie-
- Check the front disks as they are bloody expensive- 330mm & only from renault ( or ktec do a modified set)- looking at £500 for the disks alone- so more like £700 with pads fitted
Other than that there good cars-
Oh & buy a PH2- Obviously LY is the most sought after colour- but most of the range can look great-
If you do buy one take it to one of 2 places for work-
SG motorsport
Mark fish motorsport
cheers
Steve
and if that hasn't put you off, coil packs seem to fail regularly on them, all though not astronomically expensive.
Body panels are so extortionate it'll make your eyes water, and wheels cost a small fortune if you ever need to replace one!
in terms of looking for a PH2 Id want 14k in my back pocket- Id be looking for a low mileage Illiad or poss black for around 12750....
If you have the wedge wait for a LY ~ 17.5k
Ive sold 6 or 7 & the LY is by far the most sought after.....
S
LOL.......
I should have included you on the servicing list!
S
have they been tested via forum cars yet? I remember someone else came out with a disk & it fell to bits...
20mm to small
S
lol= bromley car pageant 2006 IIRC & mine was the acid... with the shiny correctly libed up exhaust...... ;)
S
20mm to small
S
Yeah these are hot off the press. Forum member on v6clio.net sent them his discs. They aren't available on the APEC website, only through selected suppliers.
Oh good stuff.....
Lets hope they cut out some of the heavy cost of the standard units-
Steve
The pair Inc. VAT and delivery £114.48
Contact:
Paul Temperton
renaultpartsdirect@gmail.com
OEM Discs (v6 club members)
£358.20 pair inc vat and delivery
