Hi folks...little help please...
  182 Cup
Yesterday my clio started stuttering REALLY badly, ive got a square(ish) light flashing on the far right of the panel...i was advised that it would most likely be the coil pack.
I purchased one today, its quite long and thin but i can see nothing that looks like it in the engine bay!
Have i been given the wrong part?
Am i a r****d?
If the answers yes to both questions i would really appreciate some help!
Has
  RS 182 - Black Gold
Firstly wot model is it?
an exact year etc... will help us greatly.
Has
  RS 182 - Black Gold
And if your car doesn has the "pencil" coils there are 4 of them that cud be at fault....
Has
  RS 182 - Black Gold
right, in that case you have been given the wrong coil pack.
the 1.2 16v engine
uses a small square coil pack with the 4 plug leads attatched to it (non removable)
So u need to go get it changed for that.
There are many other possisbilities that can be causing the problem too....
Has
  RS 182 - Black Gold
IIRC when i last paid for one its about £55 as its one unit.
Ive had 2 go on mine already since ive owned the car.
Also check the electrics at the back fo the engine (metal housing) those wires can get cut away or soaked by water...... and cause similar problems.
