Cheers Biran..so If a i get one of these line level jobs I wire that in as you say, + to the right and - to the left then connect the line level adaptor to my amp which then goes to the sub...
BIRAN ???? do you work in an Indian restaurant??:dapprove:
The RCA cables go from the adaptor to the amp and you can pick up the remote from the back of the head unit.
If its the standard Renault head unit, its pin 5 on the connector (the one thats hidden from view) count 1-3-5-7 right to left on that row.
You didn't say if your amp has MONO input and a low pass filter ?
You will need a trigger to switch the amp on and of course you will need to run the main power cable to the battery. So you cant avoid running cables.....
I cant remember what inputs there are on the MRD-500, I will have a look in a mo.
Oh right...so I still need to run the power and the remote...I'm guessing I'm still going to need to put a ground in to somewhere? so does the line level adaptor only save you from having to run the RCA's all the way through thee car?
I'm sure someone said there is an amp that actually gets the power from the speakers? or am I getting very confused and it's actually just a way of running the RCA's due to there being no RCA output on the back of the standard headunit?!?
I will have at home somewhere...at work at the moment...
on a slightly different note...I have a Blaupunkt (sp) headunit...at the moment that I'm thinking of putting in the clio as it has an 80 gig harddrive with it...are there cables for this for it to connect to the display and stalk control's?
If your head unit is equipped with line level output (RCA connectors) thats obviously the best way to hook up an amp.
If it isn't, then the adaptor reduces the output signal that goes to the speakers (high) to the same sort of signal that comes from the RCA outputs (low)
If you use this signal via the adaptor to drive an amp, then you still need power from the battery, signal to switch it on from the head unit and of course an earth.
The RCA cables then connect your amp to the adaptor.
OK so Far ?????
If you are connecting up the amp to drive the speakers in place of the output from the head unit, then you use both channels (Stereo)
What I was telling you is a way of leaving the head unit driving the rear speaker but then tapping off a mono signal from them to drive the amp, via the adaptor, in single channel mode (MONO) to drive a sub woofer.
