HID sidelights
yeah i just ordered a set for the interior light
saves me trying to mod it and build a cool running regulation circuit
i think they would look good as sidelights but not sure as an interior light
can't really tell as it's still light
some pics of the 1W LED's - very bright and a great angle on them unlike the previous '4 LED cluster' ones i had.
ones slightly more blue'r than the other (same thing happene with the 4 led cluster ones)- think it must be to do with a slight voltage difference.
still not 100% convinced
does seem to give off a strange light:S
Guy said:
Well the standard sidelight bulb on the clio like most cars is glass and the led ones you've put in are more than likely plastic therefore they could melt from the heat of the xenon lamp or even the high beam bulb.
What Alan says is true, I have seen cases of the LED's melting due to the high temps that the normal headlight lamps operate at, but it is rare in Clio's due to the sidelights being sighted next to the high beam which is never really on for long periods.
