High RPM From an F4R Engine.
I'm not sure about the oil pump and crank, but I think you start to see valve float above about 8k.
didnt ktec test a head years and years ago at high rpm for periods circa 8400rpm and the rockers began to break up?
but as above speak to matt at tdf
You don't need solid lifters for 8200RPM but what you do need is sensible life on the roller rockers. They don't last long above 8000RPM and 8500RPM is the absolute limit for them. We have uprated ones with a DLC coating that last longer but still only rated for 1000KMs of race use in the S2000 engines.
7800RPM can be done on stock stuff, 8250RPM requires stiffer valve springs and good quality new lifters. Be aware that by increasing the valve spring stiffness you are also increasing the load on the cam drive and as such should investigate if the clamping load on the cam and crank pulleys to ensure they are sufficent to retain positive location as well as what second and fourth order vibrations are present. You will want to keyway both the crank and cam pulleys for sustained used above 8000RPM.
The entire bottom end rotating assembly needs to be balanced to a sensible tolerance (note not crazy money heavy metal weighting type stuff just sensible), the stock crank is fine to 8500RPM but we do a steel one should you feel the need to be £2200 poorer. We also do an uprated steel rotor for the stock oil pump assembly which is safe to S2000 rev limits but you're probably fine on an OEM spec pump to a transient 8200RPM.
Thanks mate, that's some really good information. Thank you for taking the time to post:)
How much are the rockers and oil pump internals? Id rather the oil pump is over spec'd for the application rather than on the limits.
The R.A. Is being balaced at the moment.
Cheers Mike
PM me for prices but not cheap. IIRC the rockers come in at over a grand, DLC coating alone is £350 as essentially they're 32 bits not 16 as the roller and arm require seperate coating operations. Do you really need another 200RPM that much? ;)
