Hole Through Bulkhead
Car  Clio 182 FF
Not sure if this is the correct area but people to stuff with relocating batteries and installing amps so here goes.
Is there a hole in the bulk head ~20-25mm? I'm assuming no but is there an easy way or easy place to put it. The hole would need to come from the engine bay into the cabin. Any help would be much appreciated.
There is a grommit under the glovebox in the firewall, I just stabbed a hole in it and fed my amp wire through. (with a lot of swearing)
Can't remember roughly how big it was though.
Good thread but the hole needs to be bigger, guessing I'd have to drill it, where would be the easiest place to do this, somewhere that I could get a drill in and also be able to rustproof the hole?
The bonnet release gromit is easily 20-25mm I'm sure. If you're drilling literally anywhere that,s out of the way of heat. gally might be able to help you with anti corrosion protection on panels.
