Horn Stopped Working (MOT in few days)
Car  1.6 16v
Hi, Anyone got any ideas why my horn has stopped working on my 1.6 clio mk2??
Fuse ok because i have checked that!
Help Please
Steve
mk2s...removed the splash guard on passenger side and its right infront of you. as said..probably a loose wire.
thanks for the help, do you think it could be a lose wire on the horn then rather than inside the car?
apart from a wire not connected what else do i need to look for?
Steve
Has it ever worked? as said, check the horn connectors are fitted properly and not corroded. Also if you have a multimeter, check your getting voltage at the horn as you operate it.
ok, thanks everyone, how do i get to the horn connectors??
yeah its worked, not tryed it this year tho untill today! mot in a few days too!
Steve
find the horn. On my 172 its down behind the n/s front fog behind bumper. maybe the same on 1.6 but unsure. Best to try pull back the arch lining or remove the bumper and look.
The wires sheer off in the rotary coupler behind the steering wheel alot too.
Ive come accross this as the main problem on the Mk2
3 cars of varying age. One as new as a 54 plate....
Airbag off and trim, clearly see the wires have broken on the ring.
But dont discount wiring down by the horn behind splashgaurd and/or dodgy horn.
some wires on the connectors underneath my airbag came off, renault sorted it for me though under warranty.
Edit: Dont know how to remove it :D
I had that on my mk2 ph1 just packed the connectors for the horn with tin foil as they were a bit loose, did the job and passed MOT.
SORTED!
Thanks for all the help, connectors were covered in crap so cleaned them up and job done! Took arch liner out at the front and made easier access!
Steve
Beep Beep lol
