Dicky Belly 3
Just got back from a drive to pick something up for work and half way through the drive something has happened. The car is making a god awful rattle /grinding noise when the clutch is pressed in and when the car is at low speed. Also noticed that when changing gear and letting the clutch return to its normal position resulted in a knocking noise much like a failed dogbone Bush but it won't be that.
Clutch is only a few months old too.
It's loud enough to make people turn around when it happens! And enough that my work colleague was concerned enough to say we should pull over and have a gander so it's pretty audible! Any ideas?
Not having much luck really.
