How do I change the sidelights and side repeaters?
  Jap Box
Hi,
I have a clio mk2 ph1.
I have had a bash and messing around with the sidelight holders but cant seem to figure out how to remove them, tried pulling but it didn't budge and I didn't want to put too much pressure incase it snapped off.
Also, how do I access the side repeaters to replace them? The wheel arch was in the way so I couldn't even see them from there :p
  182
If they arnt the same as the Ph2's which are rubber then the plastic versions usually twist then you pull off.
  BMW E92/Audi S3
Rubber seal covering the sidelights at the back of the headlight unit. Take it out to access sidelights. Tight squeeze.
Side repeaters prise out. Cloth and butter knife.
  Jap Box
Did try this but had no luck, ill give it another bash though. Managed to twist and pull indicators off easy enough.
The little sidelights in the headlight units just pull out. The little plastic holder comes out as well, then once they're out you can pull the little bulb out and put a new one in, then push them back into the hole they came out of.
  a low one
the indictaors just pop out of the wing easily, use a flat head screwdriver taped up so it doesnt scratch the paint! and then twist the light yellow'ish coloured piece of plastic and the back will come away from it. they can sometimes be stiff but mine pop on and off no problems! :)
  Jap Box
Thanks guys :) ill have a bash at this tomorrow morning when im giving the car a good clean :)
