Mine is broken. Well, it never goes over 3k. I have had to dash out and messed with the dials, they move very freely. The car itself is fine, running it on a rolling road gives correct rev readings... so just wondered where the counter gets its reading from?
takes a signal from the coil for each time a cylinder is fired... divide that by 4 and you have your revs.... not sure exactly how a newer coil will work but on a older system it will take the signal from the dizzy which fires the coil - not from the actual HT leads mind!
Irrelevent to you but if you buy a aftermarket rev counter it will usually give you the choice via a switch for the number of cylinders... its a s simple as that.
Def your dials buggered. if it wasnt moving at all then Id be looking at the wiring etc but as it moves slightyly it would point to a prob with the dial itself.
