How easy is it to remove front inner arch liners?
  172 Cup SOLD
As title says really....need to whip them out for the mo until the coilovers get set up properly.
  Scirocco GT 210
Well it can't be difficult, one side of my front inner arch liners has removed itself! lol.
I know the rear is easy, couple of screws, fronts can't be any harder.
  BMW 330D
They arent hard to remove at all. They are screwed into the front bumper on one part, then they have black plug things that you need to pull out. Easy
be careful with pulling the plug out mate, theyre designed to be pushed in and then stay in. had to buy a new set when i was mucking about with front bumpers as the more you push and pull the more they ware out and dont sit tight.
jamie
  BMW M3
yeah, just a couple torx screws on the inside of the arch and under front bumper, and just a little brut force with the rubber plugs.
  172 Ph1/Scooby MY00
Two torx screws on each side and then remove all the 'fir-tree' clips.
Cheers, Rob669
  Clio 172 mk2
jamie
Yep...I'd reccomend buying some spares as well as they do get really mangled when removing no matter how careful you are.
how much are the spare plastic bits btw? i removed the arch liner to get acess to something the other day and i fucked up 1/2 of them.
  172 Ph1/Scooby MY00
Fir Tree clips were 49p each in 2001 prices (the date of my version of Dialogys).
Cheers, Rob669
cheers mate will look into this how much does it cost to do such a thing mate or could i do myself with some oil ?
Underseal only cheap £20 or less from Halfords for a tun then an old brush to poor it on stick some newspaper down to catch the drips and don't forget to only apply it after you've clened it you don't want to lock water and dirt in realy.
cheers mate thanks for that i really dont know what is best to do really i will see if i can get the archs attached better some how if not i will get the buggers off and seal the git he he...i it clear stuff mr edde
