How Easy Is It To Replace The Dials (Speedo/Revs)
Car  Coiley'd Clio PH2
Today i decided to start spraying my speedo surround but in the process of removing it, i managed to scratch up the Dials!
So they now need replacing.... how easy is this to do?
Can you buy the sheet and just swap them over or do you need to replace the whole unit?
Any help appreciated
Nick
Need to take the whole dash top off, think the the bit with the revs/speedo can be changed over.
Be careful when you take the needles off though, they're supposed to go back in similar positioins.
Yea, ive had it all off today. The needles were off... done all that before (It went horribly wrong the first time i did it)
Just not sure how the sheet that displays the speed/revs/fuel/temp comes away from the unit?
Ive just asked the bloke selling these if the dials in the picture would be what it actually looks like if installed in my car. If it does i think ill order up a set. I was going to change the smleds if i could but this could be a way around it.
I think the dials peel off and you just lay on the new ones.
