How far in advance can I get an MOT?
  Cup 172
Its due on the 23rd of this month and have a feeling it might fail on the handbrake. Would like as long as possible to sort ot out...
Ta,
Phil.
MRBILLYUK
  FF Jeden Osiem Dwa
If you think your handbrakes fcuked get it sorted before its due its MOT .
  Cup 172
Okay.... I suspect. Did the rear brakes and to start with, it wasnt gripping as well on one side. Seems to be okay now and certainly works well enough to use, but before I take it all apart again, I would rather find out if its okay...
MRBILLYUK
  FF Jeden Osiem Dwa
The only way to check it , is take it to a garage with a rolling road that does MOT's and get them to check it .
  Mercedes SLK350
I'm fairly sure you can take your car for an M.O.T. a month before it runs out.
Take your old M.O.T. so the date of the new test certificate can continue when the old one expires.
you can mot a car whenever you like as far as i'm aware. it will last for 12 months from the test date tho
MOT it whenever, if it's within one month of expiring they'll add the extra time on. Hence why some cars are advertised with 13 months mot.
