How hot does your valver run
Car  Valver
Still a bit paranoid about this valver, my RT never used to run this hot, obviously bigger engine etc etc so at what level does everyone elses valver run at?
mine never sees half way either, low temp thermostat and fan switch, fairly new rad, and clean as a (green) whistle coolant
Never goes over half way.
Newish rad, low temp thermostat and switch.
Also flush the system with a hose every 6 months. Always a bit paranoid about coolant systems. Stems from my 5 turbo days.
hmm ok need to do a coolant flush then :( mine runs pretty much always over half way sometimes a bit higher!
Yep. Probably do wonders!
Gave mine a flush and no change, the rad is all clear aswell.
Normal driving it sits on the 2nd big notch just past half way and the first fan cuts in 2 digits more.
My mates on the other had that we also flushed at the same time sits dead centre on the gauge and the 1st fan just custs in out with the gauge not moving at all really.
