want to lower it 30-35mm ish on shocks and springs. how much and where from? dont want coilovers or something thats gonna cost a bomb just good priced quality gear.
cheers.
Carno can get what you need mate. I run adjustable Konis with a 35mm drop on PI springs. The complete Koni kit have their own springs but its still a 35mm drop. About £400 for the whole kit now I think?
Adjustables are handy but to be honest I run mine fully hard all the time anyway.
if youre only lowering it for looks then use a welding torch ..
heat the lower coil at the point the spiral goes upwards.. let the car gently settle as the coil bends.. a bit at a time until you get the height you require.
let it cool naturally.. you will need a couple of plumbers kevlar heat sheilds at a couple of quid a piece to protect the inner wing and shock body.
cost...... zilch.. effect.... same as buying a simple lowering spring..
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
