latza Car recaro'd 172 rep Apr 13, 2010 #1 just had a look at my new coileys, this is the top piece of them excuse the black hand its asif you need to put the top rubber from the standard suspension on top. then slide threw car then the top rubber bit any help as im abit stuck?
jablitt Car Clio 172 Apr 13, 2010 #2 yeah, you use the standard top mounts. try and explain where you are stuck a bit better.
powey Car 106 GTI Apr 13, 2010 #3 Thats the spring hat top mount goes on top of this from what i remember
latza Car recaro'd 172 rep Apr 13, 2010 #4 wat a fluck on, meens the spring compressors need to be found, gives me a job to do tommorow, thats all just wanted to make sure i hadnt lost anything
ipodsandguns ClioSport Club Member Car GW X200 CUP Apr 13, 2010 #5 it goes spring, that thing in your hand, the oem top mount rubber part, car then the top hat.
F Fred@BTM Car Lionel Richie Apr 13, 2010 #7 you don't need spring compressors with coilovers! wind the platform down
ipodsandguns ClioSport Club Member Car GW X200 CUP Apr 13, 2010 #8 I think he means in order to remove the top mount from the OEM shock with bearing etc.
