the ESP and Traction Control Indicator Light / Service Light are coming on now and again,when I turn the ignition on/off,they go off..
the brake pedal has to be pressed a lot,for the brake lights to come on. I took the brake senor switch out,how do you adjust it?says on here to pull or push,till you hear a click..when it did it,nothing happened..
when you take the switch out,the brake lights are on,tap the end they go out..which way(if it can be adjusted) would you have to adjust it.?,the mot is due soon.dont want it to fail..
I don't want to buy a new one,until I know that's the fault..
