how to brake air con
  C63 AMG, F430 & 172
as renault wont fix my air con or even re gas it....i need to damge it to look like a pipe has split etc.. how can do this?
  renault clio 1.8 16v
do you aslo no what refrigerant the systems running as if its old and run's on r12 its illegal to fix it and it'd have to be dicomisssioned or retro fitted mega bucks mate
you could find the tev expansion device near the bulk head and losen that off and take the o ring out that'll f**k it mate.
  C63 AMG, F430 & 172
its on a 182 m8...i need to brake it coz renault want me to pay for gas as ive lost gas out of a closed unit? i was liek yer but anyways...so im gona brake the fucker so they can replace the parts..then re gas it foc..
Steve
  LMC10, Puma E
ben_p said:
its on a 182 m8...i need to brake it coz renault want me to pay for gas as ive lost gas out of a closed unit? i was liek yer but anyways...so im gona brake the f**ker so they can replace the parts..then re gas it foc..
Get it regased £85............needs doing every 2-4 years depends on usage.
If you damage it...........& they don't fix it, going to cost s**t loads.............
  C63 AMG, F430 & 172
oh they will fix it...
or i could jsut let the rest of the gas out.. so they have t fil it up to see if there is a leak....then if there isnt one... i got free gas
  Tesla MP3 2021
If you damage it...........& they don't fix it, going to cost sh*t loads.............
yeah but £85 is alot of ££ for some of us..
renault will have to put gas into it to find where it is leaking from.
  Tesla MP3 2021
that will prob be the best idea to let all the gas out.
Steve
  LMC10, Puma E
Biffons_Bridge said:
that will prob be the best idead to let all the gas out.
As part of the regassing process they;
Empty system,
Add dye + lubricant under pressure.......lubes all seals & shows any leaks,
Then regas.
Maintenance is part of owning a car, £85 is not a lot of money to keep your motor tip top.
Too many spend money on mods etc with looking after the BASICS.
  Tesla MP3 2021
so in answer to the question if we let all the gas out they will re-fill it when they are testing it and say there are no leaks....
  Focus ST
How long does this take??
Can it be done under the renault minute opening, or does it have to be booked in for a bloody day for 10 minutes worth ot work??
(I'm not too bitter am I)....
car air con will always lose the refrigerant over time because of the vibrations throw the car, engine, etc.
if its left un-used throw winter the seals dry up and let buy, thats why they always tell you to run the air con in the winter at least once.
as forletting all the refrigerant out (gas) where the connectors go if you take the black caps off (they look like tyre valves) and depress the srader valve with a screwdriver this will let it go. also it would be better to do this on the smaller pipe as this is the high side of the system under more pressure you'll get a fluescent dye come out with it so don't be to alarmed.
Just go to a better dealers who will fix it?
If you want to break it just disconnect the pipe let the gas out then plug it back on.
Or better still replace the pump with the k9k replacement no aircon but more power.
  Tesla MP3 2021
i just really dont want to pay any money to get it refilled so im going to try sommet before it goes into reno again!!! on wednesday.
  Shhh
whats in the system know its not a fully fledged air con system, is it full of R135a then i assume, as anything else would of been banned under the montreal protocol.
