How to care for your clios paintwork
This guide was produced with the valuable assistance of 182blue and R-Jay-Cup.
WASHING
Poor washing technique and the wrong tools leads to the majority of swirl makes and marring that you see on your cars paint. Swirl marks can be caused by both badly washing by hand and by automatic car washes.
Most good quality car washes are mild on wax, and all of the cars exterior components. The shampoo needs to foam up well and provide good lubrication to stop the dirt scratching the paint, and leave a good gloss finish to the cars appearance. Most car washes are much of the same if you pay for a reasonable one. Like most things everyone has the personal favourite, as long as it foams up well, produces a slick wash liquid that rinses easily and leaves a good finish I’m happy. I tend to avoid the all in one wash and wax type products. I would rather worry about protecting the paint as separate step.
THE TWO BUCKET METHOD
The favoured method for cleaning a car by hand is known as the two-bucket method. Making sure the paintwork is cool and working in the shade if possible, firstly you need to hose the car down to remove as much of the loose dirt. Hosing alone will not remove all of the dirt, nothing short of a good scrubbing will do. This is where people first introduce marks into the paintwork in the wash process by using a sponge.
The best solution to this is to use a good quality deep pile wash mitt or pad. These hold lots of soapy water and are kind on your paintwork. Unlike normal sponges these are either made of sponge covered with microfiber, cotton or sheepskin, or as a mitt to wear on your hand. The nature of the construction means that the deep pile lets the dirt get drawn down into them away from the paint protecting your finish. Traditional use of normal flat-sided sponges can’t do this, allowing the dirt to be trapped in a sandwich between the sponge and the paint. The dirt and grit then marks and swirls the paint surface, most noticeable if you have a dark paint. Even with a good foamy shampoo, the sponge will still cause damage that will later need to be polished out.
For this process you need two buckets, one with a good quality car wash and water mixture and one with clean rinse water. After washing a part of the car, instead of going straight back into your soapy bucket of wash and back to the car, use the rinse bucket to wash your pad or mitt before putting it into the soapy water and onto the paint. This means your wash bucket stays free from dirt and grit and stays foamy longer. As mentioned earlier choose a wash that is designed for car paintwork. The formulation will allow abrasive dirt to be safely removed with out scratching.
Start from the top and work down, this means that firstly you are starting with the roof, which tends to be the least dirty and allows the soapy water to run down and loosen the dirty bits lower down. During the cooler times of the year it is possible to wash the whole car and then rinse, in summer it may be advisable to do a side of the car at the time or even a panel at a time. You need to rinse often before the shampoo off before it dries, if it does it will streak and leave a film behind.
As well as washing the panels in an order steer clear of washing in circular motions. This way if by chance you do introduce swirl marks during the wash process, the circular motion will make the marks look much worse. For vertical surfaces such as doors, and wings wash in a top to bottom (up and down) motion, and for horizontal panels like the roof and bonnet wash front to back in straight lines, this way any marring caused wont show up so badly in the light.
RINSING
After washing give the car a rinse with a constant flow of water. The best way to do this is with the nozzle of the hosepipe, which allows the water to sheet off the panels rather than bead making drying the car a lot quicker. If the surface is well waxed this method will leave hardly any water to dry up.
DRYING
For drying I prefer to use either or a combination of a synthetic chamois and/or a mirofiber waffle weave drying towel. The latter is probably kinder to you paint. Again start at the top of the car and work you way down. If using a good size towel of chamois place it flat against the paint and pull it along absorbing as much water as you can in one pass. Ring and/or rinse it out often. To prevent steaks fold the towel or chamois into a pad for the final wipe.
WHEEL CLEANING
Taking one wheel and arch at a time rinse of any lose brake dust and dirt with the hose (make sure to get right in the arch with the hose), mix up your car wash to double the normal strength. It maybe a good idea to have a specific bucket just for your wheels so you know there is not any danger of the break dust getting on your paint next time you wash.
If the wheels are really dirty use a wheel cleaner to loosen up the baked on grime. Beware of most wheel cleaners, as they are acid based. I prefer to use Autoglym engine and machine cleaner as it is non acidic so is kinder on your alloys. If you are using an acid based cleaner consider watering it down to reduce the strength. If you have polished and waxed you wheels in the past soapy water should be all you need to clean them, as the protective coating left behind should stop the brake dust etching.
After letting the cleaners do their work for a few minutes, with the soapy water work your way round the tire, the face of the wheel, inside the spokes and rim. If you have very hard to clean wheels with small spokes, use a soft brush to get inside them best you can. After washing rinse the wheels and arches well with a good supply of water and dry.
USE OF THE CLAY BAR
What is a clay bar, and what can it be used for
Clay isnt a polish or a compound, it is a surface preparation bar that smoothes the paint and removes contaminants, Clay is not a replacement for polishing. Its a tool for quickly and easily removing surface contamination
A clay bar is as its name suggests a bar of clay, and is usually used in conjunction with some form of lubricant (or even normal car shampoo), and basically it is used on your cars paintwork/wheels/ and even glass, to remove surface contaminants such as tree sap, tar specks, brake dust etc.
The clay is used after washing the car and before applying waxes etc.
Clay is also very effective on paint over-spray.
Do you need to use a clay bar?
No matter how much you wash and wax your car this is not enough alone to remove certain contaminants, in fact waxing over such contaminants will only seal them onto your paint.
To check if you need to clay simply was your car and dry now simply run your finger- tips across the paint surfaces, which should feel as smooth as glass, if it doesnt then your paint is being attacked by contaminants, Removing these surface contaminants (tar, acid rain spots, bug residue, paint over-spray, brake dust, hard water spots, etc.) will improve both the look and health of your cars paint.
Using clay
Using clay is easy but do follow the manufacturers instructions, if you dont you could create a mess or mark your paint.
Firstly ensure that you car is thoroughly washed and dried, as with all car cleaning try to do it in the shade, and apply to a small area at a time. Then roll your clay into ball, this warms it up and makes it more usable, then mould it into a flat surface, you then spray a small amount of the lubricant onto the panel, and then rub the clay in back and forward motion using light/medium pressure, if it becomes hard to rub then you need to use more lubricant (this is because clay is quite sticky). When you have made a few passes rub your hand over the area and it should be smooth, if it isnt then you just follow the same process again until the area becomes glass smooth, when smooth remove all the residue with a micro fibre towel (a soft cotton towel will suffice also).
When you have completed the whole car it is advisable to wash the car down to remove the lubricant, you car is now ready for glazing/sealing/waxing, etc.
Tip, when you can no longer fold the clay into a clean surface you can use it for claying your glass or even your alloys, it surprising how much dirt you can remove from your cars glass, and likewise clay is perfect for removing brake dust from your alloys (Clay is not recommended on wheels that do not have a factory clear coat or powder coat finish).
Clay safety
1. Clay does have a mild cutting action so be careful in its use.
2. If you drop you clay bar dispose of it, as dirt will engrain itself into the clay, and this will of course scratch your paint.
3. Fold your clay regularly and check the clay often, if you find raised bits remove them with you nails
4. Always Read the manufacturers instructions.
POLISHING
The term polish and wax are often misunderstood, mixed up and used in place of each other. It does not help when a lot of products on the market blur the lines between a polish and a wax. A polish is a process that should be undertaken infrequently and is simply used to remove minor blemishes, surface scratches and swirl marks. Once you have polished your cars paintwork it will feel smooth. Polishing a car will remove under the surface defects in comparison to the clay bar above which removes above surface defects. However polishing offers no protection and should be followed with a suitable wax or sealant or indeed both!
Types of Polish
Cutting polishes – These contain tiny abrasive particles and actually remove a very fine layer of paint from the surface of a car. These are also called body scrubs and swirl removers.
Glazes – These are pure polishes and do not actually ‘cut’ the paintwork, instead they nourish and add a deep gloss appearance.
All in ones – These are often what your local Halfords sell and will include a cutting agent, a glaze and a wax all in one. They are quick and easy to use but do not offer the same level of shine or protection as completing the steps individually. In addition regular use of these is not recommended due to the cutting action.
How to apply polish
Do not apply in direct sunlight. Polish can be worked in by hand (foam pad) or by using a random orbital buffer. There is no need to let it dry but do work it in well. It can then be wiped off with a soft towel to prevent scratching the paintwork. Your paint should now be smooth and ready for waxing!
WAXING AND PAINT SEALANTS
After all your hard work so far you will want to protect your finish from the elements. Waxing or sealing your cars paintwork is a sure fire way of achieving this.
WHICH WAX FOR ME?
There are a vast array of waxes on the market from paint sealants, carnauba waxes and cleaner waxes (all in ones). Waxes also come in paste and liquid form so, which is best for you?
I haven’t stated any wax manufactures below as all manufactures produce a wide range of waxes, however respected manufactures include Mothers, Meguiars, Poorboys, Nattys, Klasse, Zaino and Zymol though this is expensive and similar results can be achieved for a lot less. Wax products bought from Halfords are generally best avoided. Given that Autoglym extra gloss is a good paint sealant.
Pure Wax
More often than not these come in paste form in a tin. They provide your car with a warm gloss look but are not overly durable and require re application every month or so depending upon your cars usage. These waxes can be very good at hiding (covering) swirl marks in paint
Paint Sealants – (Synthetic waxes)
These are in effect synthetic waxes. These last longer than the traditional carnauba wax but purists would say do not offer the same level of warmth to your paint that a carnauba wax would. These often come in a liquid form and are often applied to the car as a whole and left to ‘cure’ before being buffed off. For a great look ‘top’ your paint sealant with a pure carnauba wax for added shine and protection.
Cleaner Wax
This is a mixture of polish and wax and in effect combines the steps of polishing and waxing. Often these contain cutting agents and can hide or assist in the removal of swirl marks. A cleaner wax is useful to save time but will not give you the same results if the steps are done individually. These are best avoided for regular use but can achieve good results on older undamaged paintwork.
Colour Waxes
These contain synthetic waxes and heaps of colour ‘fillers’ which very effectively hide the swirl marks and scratches on a car. However the fillers tend to wash out revealing the scratches again. These are best avoided and any swirl removal should be done in the polishing stage above.
Applying Wax
Work in a cool shaded area out of direct sunlight.
Use a foam pad to apply the wax.
Work on one area at a time. Some products may allow you to coat the entire car before buffing off, but most do not.
Follow the wax manufacturers instructions on whether or not to allow the wax to dry before buffing.
Use a small amount of wax at a time, and rub it in well.
If the wax residue does not buff off easily, switch to a clean micro fibre or terry towel.
Apply your wax in a back-and-forth motion, not in circles. If you are creating swirls, you need to replace your applicator or towels.
A second coat of wax can be applied typically 24 hours after the first to ensure complete and even coverage.
Waxes can also be layered, e.g. applying 3 – 4 coats for maximum protection from the elements.
Gus
  182Turbo,DCi90
Got a question or two: when you are applying waxes or polishes, you say you should go up and down, does the same apply when you are wiping it off ? or should you go left to right to cancel out the up and down.
Ive been wanting to use Scratch X , do you use it over the whole car like wax, or do you apply it wo where needs it?
Thanks for the tip about the clay being reused for glass and alloys, got loads ive been reluctant to throw away cause its so expensive.
Quote: Originally posted by optical on 01 February 2005
Got a question or two: when you are applying waxes or polishes, you say you should go up and down, does the same apply when you are wiping it off ? or should you go left to right to cancel out the up and down. YES SAME APPLIES, DOESNT REALLY MATTER WHICH WAY(IE. SIDE TO SIDE OR BACK AND FORTH) AS LONG AS YOU DONT DO CIRCULAR MOTIONS
Ive been wanting to use Scratch X , do you use it over the whole car like wax, or do you apply it wo where needs it?SCRATCH X IS FOR SMALL AREAS, IF YOUR DOING A WHOLE CAR USE SOMETHING LIKE THE CLEARKOTE MOOSEWAX HAND GLAZE
  Mk2 Ph1 1.2 8v
ok, so ive got a silver car and im looking for a glass-like finish, recommend some products and method please :) cheers
  VaVa
Great post - Hightime somebody did this for all the car cleaning saddos out there!!
Should be made into an article for the main site - members area of course.;)
  106 GTi
Quote: Originally posted by 182blue on 01 February 2005
Quote: Originally posted by optical on 01 February 2005 Got a question or two: when you are applying waxes or polishes, you say you should go up and down,  does the same apply when you are wiping it off ? or should you go left to right to cancel out the up and down. YES SAME APPLIES, DOESNT REALLY MATTER WHICH WAY(IE. SIDE TO SIDE OR BACK AND FORTH) AS LONG AS YOU DONT DO CIRCULAR MOTIONSIve been wanting to use Scratch X , do you use it over the whole car like wax, or do you apply it wo where needs it?SCRATCH X IS FOR SMALL AREAS, IF YOUR DOING A WHOLE CAR USE SOMETHING LIKE THE CLEARKOTE MOOSEWAX HAND GLAZEThanks for the tip about the clay being reused for glass and alloys, got loads ive been reluctant to throw away cause its so expensive.   [/QUOTE]
Clearkote vanilla moose is very mild, and wont remove defects that scratch x might. The formula of scratch x is designed to work easily and effectively by hand. If you have a whole car to do, you would be better off looking at Meguiars Pro Line/ or bodyshop range of Polishes. #82 Swirl Free Polish or # 9 Swirl Remover are very alike to the scratch x but in better sizes.
The same methods apply whatever colour your car is ;)
On my silver car I use Gold Class shampoo, and also use a clay bar with a shampoo mixture in a spray bottle as the lube for it. Currently using Autoglym super resin polish, topped with extra gloss protection (have to let this dry for at least 1 hour before buffing off), then top it with a carnuaba wax, such as P21S. Just rememeber to wash and apply and buff off products in a straight line and not in a circular motion, it is mostly down to technique.
  Suzuki SV650
Could someone possibly compile a list of products? Ie, best 3 shampoos, best 3 polishers, gloss/wax things and sealants?
Clare speaks the truth!
In fact as much as Im not keen on them the combo of ag resin and extra gloss is supposed to be fantatic on silver cars!
All application info is in guide above
sorry but theres a lot of b***ox in this guide which doesnt make sense particularly the use of the magic mitt- besides that I havent got 8 hours to clean the car every week - really - also autoglym is acid based wheel cleaner
So what exactly is b***ox.
Please enlighten us on your method for looking after your cars paintwork and write your own guide.
Its so easy to come on here and sl*g ppl off without adding anything constructive.
Also the idea of doing all the above is not to do it every week, but maybe twice a year for clay, polish and once a week for wash and wax.
BTW thanks guys, im sure
most members will have learned something, and thanks for the time and effort put into it.
dont criticise something you obviously know nothing about, if you dont have 8 hours then nobody is forcing you to do it(p.s it would take you alot longer to do all the above in one go), the whole point of the above is that you do it say once every 6 months and then you just wash down regurlaly and wax occasionally.
please keep opinions like "b****cks" to yourself as the above info took alot of time to compile and was done to help members on here who were interested in "what " did "what" in the detailers world, these members who helped with the info did the above work for free (members like you should not comment please ) ***cough*** c**k *** cough ***:mad:
  106 GTi
Thats why the guide says to use AUTOGLYM ENGINE AND MACHINE CLEANER as, as unlike there WHEEL CLEANER, its not acid based.
lol, nice one r jay, he doesnt even read the bloody thing properly before opening his mouth
cough **freedom of speech - member or not its a forum - designed for comments - and as for the c**k comment your the one driving round in a disabled blue 182 **cough
who says should not?.....fair play if you choose to give your time for free but you could hardly sell that info and nobody asked you to do it. As long as your happy thats great, the fact that the infos a touch dodgy is entirely another matter !!
still not seeing any constructive arguements to the contrary on your part. Care to point out what in you clearly expert opinions are the flaws in the techniques these guys use ?
sorry but you know this "nobody asked you to do it" how ????
and wtf does this mean " driving round in a disabled blue 182" :p
as said above, wht dont you give your expert and informed information on the above subject please:sick:
Rasp,
The above advice is no different to what youl find on bespoke detailing forums such as autopia. Nothing in the first post is bad we havent advised you to use sandpaper or a jet wash on your paintwork!
It would be useful rather than simply slating it to actually say why it is wrong I mean for all we know you may know something that the rest of the detailing world doesnt, ........... so fire away?
  Mercedes SLK350
Well this post certainly opened my eyes. Im now going to throw out all my sponges, and get a furry glove, Im sure Ive got one somewhere. lol.
Well done to those who gave up their time to put this together.
The results speak for themselves, 182blue your car is a credit to you.
hey thx, glad you like, it does take alot of time to do, but i enjoy doing it so i dont find it a problem as it gives me pleasure seeing it clean and having other people saying its clean too
Quote: Originally posted by optical on 05 February 2005
Has anyone used the Meguiars ultimate wipe ? Its £9.99 from everythwere in the UK, but i saw on the US site you can get 20 packs for $70 . If these ultimate wipes are any good does anyone want to do a group buy?
http://www.meguiars.com/store_meguiars/product_detailpage.cfm?parentURL=index_pro.cfm&sku=m-9&store=Prohttp://www.meguiars.com/store_meguiars/product_detailpage.cfm?parentURL=index_pro.cfm&sku=m-9&store=Pro
i havent tried them but did want some, start another thread and see what interest you get, if the price is good i will have a few, you just need to find the shipping cost as it could be alot and i dont think there individually packed either
copied it to word already;)
great post i was always confused about waxs and polishs!
Has anyone used the Meguiars ultimate wipe ? Its £9.99 from everythwere in the UK, but i saw on the US site you can get 20 packs for $70 . If these ultimate wipes are any good does anyone want to do a group buy?http://www.meguiars.com/store_meguiars/product_detailpage.cfm?parentURL=index_pro.cfm&sku=m-9&store=Prohttp://www.meguiars.com/store_meguiars/product_detailpage.cfm?parentURL=index_pro.cfm&sku=m-9&store=Pro
Ive used them, theyre ok, but as you say, quite dear.
r-jay-cup uses ones from pakshak, which sound like better value, and i would value his opinion, unlike others on here cough *rasp* cough.
  106 GTi
As Chris has said I use a variety of Pakshak
http://www.pakshak.com/www.pakshak.com
and Microfibertech.com MF towels.
http://www.microfibertech.com/www.microfibertech.com
Yeah they come from the states, but even with shipping they work out a lot cheaper than the Meguiars one, which looks pricey as it is and thats before comparing them to the US prices. ( all UK megs prices are high compared to the US ones, i try not look as it will upset me - hence why I try to import my own bits.)
The Meguiars ones are OK, the new ones without the edge are better than than older black edged ones, shame they cost so much and are not as good quality, or as plush as the Pakshak ones.
If you dont want to import them, good UK alternatives are the ones Autoglym sell ( trade only - not in the shops) 3 quid each, or Alex has a good range here.
http://www.seriousperformance.co.uk/sp/products/cloths.phpClothes
These clothes will last a long time if treated well, machine washable, I have had my origional ones for 3 years and they are all still fine.
I will be organising a forum Group Buy later in the year for a load of MF clothes from the U.S. I know 182blue is up for it, let me know if anyone else is.
  500bhp Scoob
Just wondering, could someone perhaps post up a selection of stuffs, for people that have never done this amount of washing/polishing etc, as i would like to order a kit, and am quite miffed what to buy.
as i would say im an amateur at keeping my cars paintwork in good health, am just using turtle wax car shampoo with a mitt at the moment, with some wax it wet stuff.
mole i think the reason that different waxes/polishes were not listed was beacuse it could cause arguments like this one is better than that one etc, but i can tell you what i use on mine at the minute (not usually all at once), but i have put them in the order that you would use them
i wash with 2 meguiars wool wash mits
i shampoo with meguiars nxt wash
meguiars/zymol clay bar (i have a few but just use one at a time)
VANILLA MOOSE WAX HAND GLAZE (as much as is needed)
P21-S Concours Look Carnauba Paste Wax (1 coat then top as and when)
i use various cloths and mits, mostly zymol and megs, but want some of the pakshak stuff, i of course have loads of other waxes etc, including mothers/zymol/swissol/megs etc etc, but have found the above combination works for my car.
they can all be bought from here http://www.seriousperformance.co.uk/sp/products/polish_wax.php#16click, and he doesnt charge postage and he gives a 10% discount for club members
With all the coughing on this forum could I recommend some Robitusin Linctus?;) (not for polishing the car)
[Edited by Red Clio 52 on 06 February 2005 at 8:20am]
This is my own personal preference and I do this about twice a year, otherwise I just wash weekly and wax once a fortnight. It seems to work well on my dark coloured cars:
Wash with 2 bucket method, NXT shampoo and wool wash mitt.
Clay with megs pro clay and quik detailer
Polish with meguiars body scrub
Glaze with Meguiars new car glaze
Seal with Meguiars NXT wax (synthetic wax), all over and leave for an hour before buffing off. Repeat this for 24 hours later and if necessary I may then apply a coat of caranuba wax such as meguiars #16 as in my opinion a caranuba wax beads water a bit better than NXT alone.
The above takes a full day in spring or summer but as long as the car is properly waxed and the wax caoting is maintained throughout the year all you have to do is wash the car and it comes up looking A1.
  106 GTi
My Current Regime....
WASH 2 Bucket Method, With Meguiars NXT, Snonax Gloss Shampoo, Meguiars Gold Glass, or Zyml Blue depending how I feel.
RINSE Autoglym Autogloss Rinse
DRY Pakshak Waffle weave MF and a synthetic chamois
CLAY 3M Bodyshop Clay (blue)
PAINT CLEAN/ CLEANSE Meguiars Paint Cleaner or P21S Paint Cleanser
POLISH Meguiars Swirl Free Polish #82, Swirl Remover #9 or Autoglym Super Resin depending on paint shape.
GLAZE Clearkote Vanilla Moose, Meguiars hand polish or Meguiars show car glaze #7.
SEALANT Poorboys EX with Carnuba or Ex-p 2/3 coats 24 hours apart. Both can be used wipe or or left to cure like NXT or Autoglym extra gloss.
WAX 24 hours after sealant. 2 coats of Clearkote Carnuba moosewax, P21s or Poorboys Nattys Wax. ( just for apperance purposes as all give a deep and wet look gloss)
MAINTAIN Meguiars Final Inspection or Clearkote Quickshine detailing sprays.
Normal routine is the above once every 6 months, once every couple of months or before a show without the clay. Wash and a coat of wax everyweek. ( thw wax everyweeek is overkill, but i find it as quick to wack on a coat of P21s as it is to quick detail after washing)
Other good products I have but dont use as much these days, mainly as I have to much stuff worth looking at are:
Meguiars #16 Carnuba Wax, or Blitz Carnuba. Both very durable if your car lives outside.
Meguiars #26 Yellow Wax, Deep wet look, not as user friendly as other carnubas.
3M Imperial Hand Glaze, great look, not as easy to work with as Clearkotes or Meguiars Glazes. But chances are your local bodyshop will have some that you can grab off them.
  The Jinx
My preferred method is/would be:
2 bucket wash with wash mitt.
Leave to dry naturally but also help it along with a microfibre towel and a silicon blade.
Clay
If it needs it I then polish. Ive actually found AutoGlym Super Resin Polish to be very very good. I used it on friday to polish out a poor paint repair.
Then its Meguiars Gold Class Wax.
Other products I use are SafeCut/Scratch X for scratches and swirls, followed by AutoGlym Paint Renovator.
My biggest source of advice has been the detailing nerds on http://www.dervhead.com/xmb/http://www.dervhead.com/xmb/
Klasse All In One is very highly respected.
good guide Brazo ;)
Im not saying the previous guy was right in all he said but i agree that the part about acidic wheel cleaners being bad isnt actually true. The acid helps break up the solid brake dust on alloys and the companies obviously design the product with the right consistancy for a reason and test it rather than just releasing it to a dubious public audience.
Therefore do not be warey of using such products to clean your alloy wheels and save yourself some time.
p.s. Mark, since when is tyre spent tire ;)
  106 GTi
Have you not seen some of the damage that wonder wheels has caused to alloys? I think that there is no need to use very acidic cleaners when there are safer options out there that have no danager of damaging your wheels finish. Acidic based wheel cleaners do clean very quickly, but non acidic ones such as AG engine and machine cleaner work just as well with no extra effort. Once cleaned and polished normal car wash should be all you need to clean wheels afterwards. Autoglym realsises the consistancy of theres maybe too strong and recommends you water it down.
Constant use of wonder wheels on one of my old cars lead to all the shine going from the alloys, after that I started touse Autoglym wheel cleaner watered down. I treat the paintwork on my wheels in the same way as the bodypanels. I wouldnt spray acidic based cleaner on my panels and thats how to make your wheels look as good as the paint.
Yeah there are a few horror stories but what i find hard to believe is that a company will market a product that is dangerous to use in terms of damage to the wheel it is designed to clean.
the concentration is specifically selected and testing is done before the product is released so why would they release a product that is going to damage consumer alloy wheels? doesnt make any sense. corporate or otherwise.
obviously im not referring to the products that are supposed to be watered down and are therefore a concentrate. Im talking about the ones with spray gun heads that are supposed to be ready to spray out of the pack.
