How to keep your MBP battery healthy?
Matt Cup
  Iceberg 172 Cup
Whats the best way to keep your battery at it's best? I've been given mixed info from a couple of people at the Apple store so I'm a bit confused.
1 - Fully charge and let it run out (rinse and repeat)
2 - Keep on power adapter and periodically run the battery down to <5% then charging it back up.
So any tips on how to look after my MBP battery would be appreciated.
sbridgey
  disco 4, 182, Meglio
I charge then use it on battery until its almost flat, and repeat.
used to keep on charge constantly but the battery started to suffer.
Matt Cup
  Iceberg 172 Cup
Do you also shut it down completely after use or just close the lid (sleep mode I think?)
  CBR1000RR Fireblade
Mine always gets shutdown after use and I run the power right down and fully charge it each time.
SC03OTT
  Mk 8.5 Golf GTI
Charge up to around 80% then run down to 20%. Once a month (or when I remember, which is usually the case) fully charge then fully drain.
