How to remove bullets?
Car  Clio 1.2 16v Extreme
Hey, this is probably a straight forward question so sorry if its obvious..
how are they attached to the car and how do you go about removing them without causing too much damage?
cheers!!
mike.
Open the door. Push the whole strip that the bullets are attached to down (it should slide down about 1cm but you might not have to do this) then pull the whole strip from where it ends on the edge of the door and it should slide off. Then when it's off just pull the bullet off the strip. Don't be afraid of snapping anything, you shouldn't if you're careful. I did this a couple of days ago and it went fine.
slide em off, just be gentle, the clips can be brittle with age, cheap to buy if you bust any
I took mine off this morning... I used the 'just pull' technique and broke one of the clips in the side strip. Stuck it back down with glue though so it should be alright
