Yozza'd BG
Im trying to remove the door panels on my clio 182 to try and solve a problem with a loose component which i can hear banging back and forth inside the door when i shut the door.
So far ive removed the screws running along the bottom of the door and the screw through the door handle. ive also managed to pull of a panel which runs parallel to the B-pillar held on by three studs.
However, while the main door panel itself looks as if it is held on by studs as well, it is needing quite a bit of force behind it and nothing is happening. It looks as though there is glue stretching in there as well when i pull on it...i dont want to bust anythin!
Can anyone offer any help please or advise as to whether i should get a dealer to look at this instead of DIY?
Cheers for any suggestions,
Nick
Nick
