you dont always need to replace the gasket, there is a guide in the how to section on how to take the plenium (sp) off (the bit with renault sport on it) Basically need to un plug connectors, undo the bolts on the coil pack, unto the bolts on the plenium (sp) and gently lift it off.
You should see the ignition leads in front of you.
