how to wire dual voice coil sub
it can, but it all depends on the amp, its all down to power figures at different resistance levels
Tom
  i3
you have to be very careful with it tho. if the amp isnt balanced the sub will f**k itself
  Corsa 1.3 CDTI
If your amp supports 2 ohm or 1 ohm load you just connect both connections into 1 channel. If you Amp supports bridging mode then bridge it and run both connections into 1 channel, but you must be able to run 2/1 ohm load into you amp to do this otherwise youll screw the amp/sub.
There is alot more to this but this is a basic setup.
  350z & 16v Maxi
very very few amps can run at a load of under 4 ohms when bridged. DO NOT run both coils to a bridged channel or youll feck your amp.
If you are buying an amp for it, get a mono channel
