HT Lead Replacement
  172 Cup & K20 Ph1
Hi All
Stupid question I'm sure... wanting to replace my HT leads with some magnacore ones as I'm having a very lumpy idle and some limp mode issues. I've replaced the spark plugs and cleaned the throttle body out completely so hopefully this will fix it. Problem is, if I pull up on the HT leads (coilpack side) they seem extremely tight, how are these removed exactly? I really don't want to break it and end up not having a car!
Thanks a lot
Rhys
What Clio do you have? Sport/Non Sport. Iirc my old non sport the leads/coilpack were all one, so you couldnt just replace the leads as they were attached to the coilpack and you couldn't seperate them..
  172 Cup & K20 Ph1
Sorry, it's a 172 Cup... I must have had a really weak day as I just replaced the leads successfully!
Hasn't fixed my problems- seems to be elsewhere. Having a strange idle problem where it seems to bounce around and never just idle at ~900rpm.
