Hub nut
well i think its the hub nut. am i right in saying there are 2 torx and one 29MM nut holding the hub on + the brakes
how the hell do i get this 29MM of i been trying for ages Its REALLLY tight :-) :(
get a breaker bar on it if not try and find something that u can put over the top of ur socket set like a scafold tube or something (that is metal) u need alot of presure to get it off
Its 30mm for a start
yep you need to give them some stick to move them thats what breakers bars were intended for.
Make sue you put it back on either new (as you should) or with loads of locking compound just as tight
