Hubcentric spacers?
Car  306 GTI-6
Before anyone tells me to do a search, I have done but the info is so conflicting I am looking for a definitive answer from someone who has done it.
I have some Ph2 172 16" alloy wheels waiting to go on my 2003 Dynamique. Will i need spacers or not? Some people say no, some say yes and that i will need 5mm each side on the rear only.
If i do need them, do they need to be hubcentric or will universal ones be fine?
I know there are lots of people who have fitted these wheels as mods so looking to find out what they used etc?
Thanks in advance.
To cancel the offset difference you would require 10mm spacers.
Please define "need" and I will tell you whether you "need" them or not.
need
/nid/ Pronunciation Key - Show Spelled Pronunciation[need] Pronunciation Key - Show IPA Pronunciation
–noun 1.a requirement, necessary duty, or obligation
As in, will the car work properly without them? Or are they required to prevent rubbing etc.
Have you fitted these wheels and used spacers as i have been told by some to use 5mm spacers each side.
get hubcentric. end of.
you will NEED 5mm on the back for certain. some go wider like me, but my intentions were for better handling and wider looks.
15mm on each hub
hopefully you can see on those pics how much further out the wheels look
jamie
Cheers Jamie
Love your car by the way.
when i take the centre cap off my 172 alloys, it has 48.5 stamped, is this the offset?
cheers fella, hope you didnt have to go outside to look!
i just went to see if it was stamped on my current dynamique alloys and it isnt, but it is bloody cold! Only 6deg ffs!
thanks for the help anyway guys, much appreciated.
nay worries lad, and mines in the garage atm, after the meet 2nite she will be off the road for a weeks clean for FCS ;)
jamie
