Hi.
I'm getting tired of my MBP performance. It's getting quite laggy recently and I'm convinced the HDD is the cause. It had a fresh Lion install not so long ago and I keep it very lean, so I don't feel that the OS is clogging up. So anyway, I don't fancy an SSD in it, because I also want the option of a decent amount of storage. I recently did a test with a friend who has a hybrid drive fitted in his (same model MBP) and his booted up in half the time, and was generally much quicker at everything.
So, Apple rimmers, will THIS drive fit and work ok in a 2009 Core 2 Duo unibody MacBook Pro?
If so, I shall purchase the beast and fresh install Lion on it forthwith. Anything I need to be aware of?
Thank you.
EDIT: It's a 17" model BTW. Not that it matters. Just letting you know how I roll.
Thank you.
