Hydraulic clutch
  Clio 172 + Clio200T
Hello,
Did a search on the forums but only found partial information.
I was looking at a possible hydraulic clutch pedal.
Not wanting to replace the whole pedalbox with a racing one.. I've read some DCI models had the hydraulic clutch.. does anyone knows code or can be more precise?
My car is LHD if can make a difference.
Can someone help me finding the right part?
Thanks.
P.s. Only pedal/master cylinder, not considering the gearbox side as I may go with a different unit.
JamesBryan
Hello James, PMS do the kit for slave cylinder, but I am looking for master.
They do a kit for pedals but only for RHD, my car is LHD
This thread might help.
  Clio 172 + Clio200T
I'll try to contact the user, as here everyone list spares with codes so without It its impossible to find :(
Martin_172
The DCI 100 had a hydraulic clutch and the later DCI 68's (mostly vans) had them too.
If it has this shape gear knob its a cable clutch:
And this shape is a Hydraulic clutch:
Twingo mk2 with the 1.2 TCE (GT/Gordini) also uses the same gearbox and clutch so parts from that MAY fit and be easier to find
  Clio 172 + Clio200T
Tank you Martin, gear knob shape difference is a nice hint making finding the right model way easier!! Thank you a lot!
VenomUK
  Clio 172
Do you mean the clio van or the MK1 kangoo? I'm not sure if I read somewhere that MK1 kangoo also has the hydro clutch that can be used?
  Clio 172 + Clio200T
It's a shame as different forums disappear online, years of info goes with them
You make me remember how many forums I used to write on during years.. all gone.
Gladly cliosport is still holding on with nice helpful people and with such great informations.
VenomUK
  Clio 172
Is the hydro clutch DCI boxes have a Speedo drive or take the speed from the ABS?
Hello everyone,
Thread resurrection time!
Does anyone know where to get hold of either a dci or twingo mk2 1.2 tce pedal box for converting my over powered 182 to a hydraulic clutch?
Paul
  Clio 172 + Clio200T
Hello everyone,
Paul
Afaik twingo pedalbox is very different. Anyway.. I ended up finding a kangoo pedal box, exact same shape of clio, only a couple different things like hole for gas cable. Only had to have custom hose made to connect it to my slavecylinder as i am using a tl4 gearbox.
