The coilovers will come with all you need, however I would recommend getting some solid front top mounts, these will give better feel as your standard ones are probably shagged anyways.
As for the measurements, I cant remember which dimension is the cup packed ones, but if you search on here for difference of the cup packs and non cupped packs, then it should be in there.
Right ive been through every page of the suspension section now, ive learnt that 58mm is the damper bolt spacings for standard 182's but still non the wiser as to what a cuped 182 is? Please advise!
I am contemplating just buying decent shocks and springs instead now as there seems so many complications over which coilovers to get, ive sort of moved away from the H&R's as if im being honest with myself I dont need such a high spec'd bit of kit for the money id be paying, I'll prob only track the car once or twice, FK konigsports seem ideal for quality and cost but like I said, I need to know the spacings to know if they'll fit urggghhhh!!1!!one!!! :\
