i have bent my rear hub,how much
Car  flame red 172
after my little spin the other day and hitting acurb quite hard i have had my car up on a ramp and been told the rear hub is bent,
i wanted to know how much one of these would be?
ok i have contacted him as hes breaking a clio 172,i take it should be same as a normal 172
trophy has a stronger rear beam thats the only difference im aware of. Cup, 172ff etc all the same
If its just the hub they are the same on all 172s, not sure about 182s as they maybe a different length. As for the whole rear beam, the 172mk1 and cup beams are slightly different, but the bits from your old one needed such as the headlight adjuster can be bolted on. The 182 rear beam will fit but i think some of the brake pipework is different, its also strengthened and has a thicker roll bar.
