I was wondering....
Is water vapour or small drops of water bad for your car or induction kit if they are getting sucked into it? I know the filter is there to stop crap, but eventually water might get through. How bad is it?
And
Is wet air better than dry air? ie dry air tends to be hotter.
I was just wondering thats all.
Paul
  ExigeV6|Q5|DS3|Fiat
Not sure about the water thing, dont think much water droplets will acutually get in there.
Cold air is denser, consequently will tell the ecu to chuck more fuel into the injection. Hot air is not so good.................correct me if im wrong anyone?
water will not only cause the engine to blow but it shall end the world, we must fly this water away into space.
Water wont make any diff, if its droplets it probably wont get sucked into the engine it will trickle down then when you park up turn to steam and drop into the manifold then get spat out when you re-start.
When it does get sucked in its a very effective cleaner. If you get to much in the engine either stops or bends a con rod.
Denser air does indeed mean more juice gets squirted in.
