Ideas on non start
Car  R27 427/500 ALBI
Right come across a fault my trophy will not start ,
Battery seems fine inside light is bright also headlights are fine how ever if I try and start it just clicks and cuts the lights ,
When I was driving home I had Abs,traction controll , and service light apearing then disappearing
Any help would be good as I'm frustrated and thus is my first fault has anyone had any simlar problems
Leigh
As above... BUT most likely IMO is the wire has come off the solenoid on the Starter motor, happened on my Clio Sport ph1 and on my mates megane, feel round the back when its cold and on the left of the strater motor on the end of the solenoid (roud cylinder which sits out from the starter body) you should feel a thick wire, if you can feel it move, its most likely come loose and needs either esoldering OR the starter replacing.
Other way of checking this is to offcourse bump start the car, if it is starter it WILL bump straight away.
wayne
Well il have a look tomorrow and report back , batteries still bright , starter sounds like it clicks once then cuts ,
Il see what I can find out
Leigh
