Idle Control Valve 172
Hi guys,
I have a stalling problem and I am told that the idle valve is the culprit. Am I correct in thinking that this can be cleaned rather than replaced? If so, can anyone tell me where it is in the engine bay and whether this is an easy DIY thing to do.
Cheers,
Bat.
It's in the throttle body.
Yes, it can be cleaned. I think someone on here did a guide so check that section. You will need some carburettor cleaner spray for both the ICV and the throttle body. You have to take them both off the car to do it = quite easy.
now im not sure if i have the same problem here. is it when you accelerate hard/ hardish lol the car then just cuts out. no judder nothing. the revs just drop off
